I'm following the Raspberry Pi Quickstart and trying to setup EMS on a Raspberry Pi but it throws an error when I try to run the EMS.
[FORCE] 2018-04-12 05:38:50,298 ./wsems: Initializing EMS ....
[FORCE] 2018-04-12 05:38:50,298 main: Using config file /home/pi/microserver/etc/config.json
[INFO ] 2018-04-12 05:38:50,298 ./wsems: Creating the WsEms proxy.
[INFO ] 2018-04-12 05:38:50,298 ./wsems: Starting HTTP Server.
[INFO ] 2018-04-12 05:38:50,299 Main: Using custom certificate and private key for HTTP Server
[ERROR] 2018-04-12 05:38:50,299 Main: Failed to get HTTP Server ssl configuration.
[FORCE] 2018-04-12 05:38:50,299 Main: Exiting....
[DEBUG] 2018-04-12 05:38:50,299 jsonConfigurator::~jsonConfigurator: Deleting JSON object
Here is my config.json file:
"ws_servers": [{
"host": "pp-1804050929fh.devportal.ptc.io",
"port": 443
"http_server": {
"host": "127.0.0.1",
"port": 8080
"appKey": "xxxx",
"logger": {
"level": "DEBUG"
"auto_bind": [{
"name": "PiThing",
"gateway": false
"certificates": {
"validate": false,
"allow_self_signed":true
"ws_connection": {
"encryption": "ssl",
"verbose": true,
"msg_timeout": 1000
This is my first time doing this, any help would be appreciated. Thanks.
Hi BlackIce21,
you can try
{ "ws_servers": [{ "host": "pp-1804050929fh.devportal.ptc.io", "port": 443 }], "http_server": { "host": "127.0.0.1", "port": 8080, "ssl": false, "authenticate": false }, "appKey": "xxxx", "logger": { "level": "DEBUG" }, "auto_bind": [{ "name": "PiThing", "gateway": false }], "certificates": { "validate": false, "allow_self_signed":true }, "ws_connection": { "encryption": "none", "verbose": true, "msg_timeout": 1000 } }
Just to chime in I replaced the value of appKey with 'xxxx.' Exposing that value could be a potential security risk.
Thank you,
-- Craig A.
Hi BlackIce21,
you can try
