Connecting Raspberry Pi to Thingworx Error
BlackIce21
7-Bedrock
I'm following the Raspberry Pi Quickstart and trying to setup EMS on a Raspberry Pi but it throws an error when I try to run the EMS.
[FORCE] 2018-04-12 05:38:50,298 ./wsems: Initializing EMS ....
[FORCE] 2018-04-12 05:38:50,298 main: Using config file /home/pi/microserver/etc/config.json
[INFO ] 2018-04-12 05:38:50,298 ./wsems: Creating the WsEms proxy.
[INFO ] 2018-04-12 05:38:50,298 ./wsems: Starting HTTP Server.
[INFO ] 2018-04-12 05:38:50,299 Main: Using custom certificate and private key for HTTP Server
[ERROR] 2018-04-12 05:38:50,299 Main: Failed to get HTTP Server ssl configuration.
[FORCE] 2018-04-12 05:38:50,299 Main: Exiting....
[DEBUG] 2018-04-12 05:38:50,299 jsonConfigurator::~jsonConfigurator: Deleting JSON object
Here is my config.json file:
    "ws_servers":   [{
            "host": "pp-1804050929fh.devportal.ptc.io",
            "port": 443
    "http_server":  {
        "host": "127.0.0.1",
        "port": 8080
    "appKey":   "xxxx",
    "logger":   {
        "level":    "DEBUG"
    "auto_bind":    [{
            "name": "PiThing",
            "gateway":  false
    "certificates": {
        "validate": false,
        "allow_self_signed":true
    "ws_connection":    {
        "encryption":   "ssl",
        "verbose":  true,
        "msg_timeout":  1000
This is my first time doing this, any help would be appreciated. Thanks.
NHummel
6-Contributor
(To:BlackIce21)
Hi BlackIce21,
you can try
    "ws_servers":   [{
            "port": 443
    "http_server":  {
        "port": 8080,
        "ssl": false,
	"authenticate": false
    "appKey":   "xxxx",
    "logger":   {
        "level":    "DEBUG"
    "auto_bind":    [{
            "name": "PiThing",
            "gateway":  false
    "certificates": {
        "validate": false,
    "ws_connection":    {
        "encryption":   "none",
        "verbose":  true,
        "msg_timeout":  1000
CRArko
(To:BlackIce21)
Just to chime in I replaced the value of appKey with 'xxxx.' Exposing that value could be a potential security risk.
Thank you,
-- Craig A.
NHummel
6-Contributor
(To:BlackIce21)
Hi BlackIce21,
you can try
    "ws_servers":   [{
            "port": 443
    "http_server":  {
        "port": 8080,
        "ssl": false,
    "appKey":   "xxxx",
    "logger":   {
        "level":    "DEBUG"
    "auto_bind":    [{
            "name": "PiThing",
            "gateway":  false
    "certificates": {
        "validate": false,
    "ws_connection":    {
        "verbose":  true,
        "msg_timeout":  1000
