Connection Error using Basic Thing with Property
gherr-2
Hi all,
I am running ThingWorx on localhost using Apache Tomcat 8.0. I have modified the config.json file with IP Address  as 'localhost'. This is how the link to my ThingWorx webpage looks like : http://localhost/Thingworx/Composer/index.html. When I am trying to run the example # 3, I am unable to create the connection. Following are the logs:
SELECTED: Basic Thing with Property
Running Example #3: minimal agent w/ property
[Error] Error intializing socket connection.  Err = 111
[Error] twWs_Connect: Error restarting socket.  Error 111
[Error] twMessage_Send: Error sending Message with RequestId 1
[Error] [HomeLight0]: Error calling twApi_WriteProperty() for LightLocation - 1107
[Error] twMessage_Send: Error sending Message with RequestId 2
[Error] [HomeLight0]: Error calling twApi_PushProperties() - 1107
[Error] Error connecting - 1001
Could you please help? TIA!
ttielebein
(To:gherr-2)
Well, if you are connecting to ThingWorx with the provided URL above (http://localhost/Thingworx/Composer/index.html​), then you know that ThingWorx is running on port 80 (as none is specified and port 80 is the default for HTTP). So I don't think the comment about port 22 is entirely relevant. Might be worth a try just to swap those guys out since it is easy to check.
I don't think that "tls" is a valid parameter. If you are trying to set the encryption to false, I'd use:
"ws_connection": {
       "encryption": "none"
If swapping that syntax out doesn't help, try adding:
"certificates": {
     "validate": false,
     "allow_self_signed": true
Let me know how this goes. For a full list of valid parameters for this file, see the config.json.complete file, which should have been included in your EMS download.
7 REPLIES 7
ttielebein
(To:gherr-2)
Can you please post the rest of your config.json file contents here so I can look at it?
Thanks!
Tori
Also, I have checked the ports opened on my Rpi using netstat -tln: It is listening only on port 22 and not 80. I am not sure if this makes a difference  or not.
ttielebein
(To:gherr-2)
"ws_connection": {
"certificates": {
     "validate": false,
Thank you Tori. I replaced localhost with the exact IP address of my local machine in the conf.json file and it worked! Really appreciate your help
ttielebein
(To:gherr-2)
No problem!
Hi Tori,
I am getting the following error when I try to do Rasberry Pi 2 example . I have same config.json where I placed the IP address of my Thingworx server.
    "connection": {
        "host": "192.168.1.18",
        "port": 80,
        "app_key": "xxxxxxxxxxx"
    "tls":{
        "encryption": false
[Error] Error intializing socket connection.  Err = 113
[Error] twWs_Connect: Error restarting socket.  Error 113
[Error] [PKG_HomeLight0]: Error calling twApi_WriteProperty() for LightLocation - 1107
[Error] [PKG_HomeLight0]: Error calling twApi_PushProperties() - 1107
Any help is appreciated
This file is not formatted properly. For a full list of formatting options, see config.json.complete. Here is what you are trying to do, I think:
  "ws_servers": [{
  "host": IP_ADDRESS,
  "port": 80
  "appKey": "b7341ad4-4069-401a-97b0-7bade159e54f",
  "ws_connection": {
  "certificates": {
  "validate": false,
