Hi all,
I am running ThingWorx on localhost using Apache Tomcat 8.0. I have modified the config.json file with IP Address as 'localhost'. This is how the link to my ThingWorx webpage looks like : http://localhost/Thingworx/Composer/index.html. When I am trying to run the example # 3, I am unable to create the connection. Following are the logs:
SELECTED: Basic Thing with Property
Running Example #3: minimal agent w/ property
[Error] Error intializing socket connection. Err = 111
[Error] twWs_Connect: Error restarting socket. Error 111
[Error] twMessage_Send: Error sending Message with RequestId 1
[Error] [HomeLight0]: Error calling twApi_WriteProperty() for LightLocation - 1107
[Error] twMessage_Send: Error sending Message with RequestId 2
[Error] [HomeLight0]: Error calling twApi_PushProperties() - 1107
[Error] Error connecting - 1001
Could you please help? TIA!
Well, if you are connecting to ThingWorx with the provided URL above (http://localhost/Thingworx/Composer/index.html), then you know that ThingWorx is running on port 80 (as none is specified and port 80 is the default for HTTP). So I don't think the comment about port 22 is entirely relevant. Might be worth a try just to swap those guys out since it is easy to check.
I don't think that "tls" is a valid parameter. If you are trying to set the encryption to false, I'd use:
"ws_connection": {
"encryption": "none"
If swapping that syntax out doesn't help, try adding:
"certificates": {
"validate": false,
"allow_self_signed": true
Let me know how this goes. For a full list of valid parameters for this file, see the config.json.complete file, which should have been included in your EMS download.
Can you please post the rest of your config.json file contents here so I can look at it?
Thanks!
Tori
Thank you Tori for your reply.
Also, I have checked the ports opened on my Rpi using netstat -tln: It is listening only on port 22 and not 80. I am not sure if this makes a difference or not.
"ws_connection": {
"certificates": {
"validate": false,
Thank you Tori. I replaced localhost with the exact IP address of my local machine in the conf.json file and it worked! Really appreciate your help
No problem!
Hi Tori,
I am getting the following error when I try to do Rasberry Pi 2 example . I have same config.json where I placed the IP address of my Thingworx server.
"connection": {
"host": "192.168.1.18",
"port": 80,
"app_key": "xxxxxxxxxxx"
"tls":{
"encryption": false
[Error] Error intializing socket connection. Err = 113
[Error] twWs_Connect: Error restarting socket. Error 113
[Error] [PKG_HomeLight0]: Error calling twApi_WriteProperty() for LightLocation - 1107
[Error] [PKG_HomeLight0]: Error calling twApi_PushProperties() - 1107
Any help is appreciated
This file is not formatted properly. For a full list of formatting options, see config.json.complete. Here is what you are trying to do, I think:
"ws_servers": [{
"host": IP_ADDRESS,
"port": 80
"appKey": "b7341ad4-4069-401a-97b0-7bade159e54f",
"ws_connection": {
"certificates": {
"validate": false,
