Contained Mashup Widget Issue in 9.3
pshashipreetham
As per below picture, the Mashup is center aligned, when there mashup is selected in the Contained mashup.
When a Mashup is selected in Name widget property of the Contained mashup, total Mashup/Container goes to left top.
As per the use case, when an Mashup is selected in the Name Widget Property of Contained Mashup, whole mashup should be still center aligned.
Thingworx version: 9.3
Contained Mashup is Palced inside a Field Set.
@slangley@c_lowy@VladimirN  @CarlesColl
Shashi
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
Hi @slangley ,
Raised an PTC case, this is what they responded:
This is a bug in 9.3.
Shashi.
Shashi Preetham,
6 REPLIES 6
Hi @pshashipreetham.
It appears you're using a static mashup.  Are you seeing the shift in the preview?  Once you view it, does it still show shifted?
You could try using a responsive mashup and then in the Layout tab, change the Positioning to static.  Scroll down for setting the container size.
--Sharon
Hi @slangley ,
Thanks for the reply, the screenshots posted (in the first post) are done in the exactly in same process in which you have guided. Still the issue exists.
Shashi.
Shashi Preetham,
slangley
23-Emerald II
(To:slangley)
I'm afraid you will need to be more specific.  Are you using a responsive mashup or a static one?  If using a Responsive mashup, what other settings are you selecting?
--Sharon
Hi @slangley ,
Using an Responsive Mashup, the other settings you can find in the following screenshot:
Shashi
Shashi Preetham,
slangley
23-Emerald II
(To:slangley)
Can you provide your mashup?  We're not seeing the same behavior you've described.
--Sharon
Hi @slangley ,
Shashi.
Shashi Preetham,
