Container Style Border on 9.3
A_Macierzynski
Hi!
I am trying to remove the border of the clicked container. Every single widget has it, but I cannot find a place where it is defined. Looks like custom CSS for me. Basically, it is a blue 1px border everywhere.
Picture in attachment.
Thanks!
8 REPLIES 8
Hello @A_Macierzynski ,
Pls check this community thread for your issue:
https://community.ptc.com/t5/ThingWorx-Developers/Container-border/td-p/644204?posno=4&q=border%20of...
This article explains the How to hide the border line of Value Display Widget:
https://www.ptc.com/en/support/article/cs321636
Let me know if this helps.
Regards
Bhawna
Hi @bchaudhary
This is not the solution to my issue. My issue is not about the border overall, but only when the container is being clicked.
This appears on 9.2 & 9.3. Not visible on 8.5.
CSS from the article is also about something else.
Adam
Working CSS looks like this:
.not-clickable {
    pointer-events: none;
In our case, that's not possible to use that, as we want to keep it clickable.
Pls check the given Article - CS324593 - ThingwWorx Web Components customization with Visual SDK CSS
https://www.ptc.com/en/support/article/cs324593
Look at the part where it is mentioned:
  • Remove Focus box from UI items
ptcs-focus-overlay {
visibility: hidden;
.ptcs-wrapper:not([no-wc-style]):focus:not(.dummy):not(.dummy):not(.dummy) {
box-shadow: none;
I hope it helps your issue.
Regards
Bhawna
Didn't try it, because I found out that on 9.3 there is actually Focus section in Theme which is working for me and I was able to remove that border with this change.
Thanks for sharing the solution.
However, if you try the suggested solution and it works for you.
pls share the outcome for the benefit of other members.
Regards
Bhawna
If I refer to the article: https://www.ptc.com/en/support/article/CS324593 , it appears that the section for "Remove Focus box from UI items", proposing following CSS code:
visibility: hidden;
box-shadow: none;
only applies until Thingworx 9.2.
With Thingworx 9.3, modifying settings on the Focus section of the Theme is enough.
In particular, you can set the fourth option to "tw style-cssoption none" to get rid of the "focus box":
DanZ
(To:A_Macierzynski)
I noticed this annoying blue border only around the grid widget when clicked. I removed it with this custom CSS snippet (no custom class required):
.widget-gridadvanced[themable] {
    border: 1px none !important;
I think the reason for the invisible 1px border was that without it, the grid position was a bit off. But I am not sure right now, so you can try it with 0.
