ContentLoaderFunctions GetText is not working in Thingworx 9.1
vi1
Hello.
I am using Thingworx 9.1 version with Postgre SQL.
GetText function is not working. Got error as "Invalid Content Type: application/json". The same code it was worked with Thingworx 8.5.1 version.
var propertiesAttr = Resources["ContentLoaderFunctions"].GetText(params);
Could you please suggest?
Thank you in Advance.
Latha
5 REPLIES 5
@vi1
GetText is working for me on 9.1, refer below screenshot,
Would you be able to the code you are using?
Sachin
Thank you for response.
Here I am using url path is outside of thingworx server. When I give the url path is inside thingworx, its working correctly and also if I use GetJSON with outside server url path, working correctly. Observation with GetText service with outside server url path. Refer the below snippet which I am using for GetText.
@vi1
Are you not getting any output or are you getting an error? If it's the latter, please share the error message.
Sachin
I am not getting output if use GetText and getting the below error in Thingworx Logs.
Latha
@vi1
Updated this post with correct info.
I am able to replicate the behavior on Thingworx 9.1.
I found this article where it says that starting from Thingworx 9.0, response Content-Type should contain "text" for GetText(). R&D has confirmed that this is a bug and they will be fixing it in later releases. So, please update the response content-type to text and validate the behavior.
Sachin
