Looking to create a service that will copy/move a file from a ThingWorx FileRepositoryThing to a Windchill Product subfolder. This is to be triggered by a service call from a ThingWorx mashup. Where I have seen information is for creating a file related to primary content for a task. This would be in a subfolder under a product.
Hi @GB_10984907,
You can check the solution for a similar question here:
Solved: Automatically Transfer Documents from ThingWorx to... - PTC Community
I am looking to move the files from ThingWorx DocumentRepository to Windchill product subfolder/subfolder programmatically.
Example: Products/Division1/Item1234/Contracts
"Division1" has a Container ID: OR:wt.pdmlink.PDMLinkProduct:222222222. "Item1234" and "Contracts" appear unreachable. I have found a way to get the SubFolderID for both "Item1234" and "Contracts" but have not been able to retrieve the contents or figure out how to send files to "Contracts" or and other folders under "Item1234".
