Create CSV File Using a Service
dkeeley
7-Bedrock
Is it possible to create a CSV file from an infotable using a service and save it into a file repository?
David.
ytella
(To:dkeeley)
Hi David Keeley,
Just to add what Pai Chang has already suggested, you can refer to the below document for using the CSV Parser or Parsley extension:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS255612&art_lang=en&posno=2&q=csv%20file%20creating&ProductFamily=ThingWorx%7CNRN%7CAxeda&source=search
Hope this helps!
3 REPLIES 3
PaiChung
22-Sapphire I
(To:dkeeley)
You'd have to add your own parsing I believe and then do a SaveText (Service that is part of a FileRepository)
You could check the CSV parser extension to see if it has a write CSV, I vaguely remember it having it.
Thanks Pai. I'll look into that now.
David.
ytella
(To:dkeeley)
Hi David Keeley,
Hope this helps!
