Is it possible to create a CSV file from an infotable using a service and save it into a file repository?
David.
Hi David Keeley,
Just to add what Pai Chang has already suggested, you can refer to the below document for using the CSV Parser or Parsley extension:
Hope this helps!
You'd have to add your own parsing I believe and then do a SaveText (Service that is part of a FileRepository)
You could check the CSV parser extension to see if it has a write CSV, I vaguely remember it having it.
Thanks Pai. I'll look into that now.
David.
Hi David Keeley,
Hope this helps!
