I want to create a WTDocument in Windchill which may also contain primary content from ThingWorx (by creating a form in Mashup). I'm new to Thingworx and want to know the steps to do so.
Hi @OP_11714882,
In ThingWorx, there are 2 ways you can call Windchill REST API.
First is to create a Thing Service and use ContentLoaderFunctions.
Refer to articles:
https://www.ptc.com/en/support/article/cs237875
https://www.ptc.com/en/support/article/CS380751
Second is to use Integration Connector > ODataConnector
Refer to ThingWorx Help Center
As for which Windchill API to use to create WTDocument, I found below articles, but if you have any further questions, you need to ask in PLM community board or open a Windchill support case for help.
https://www.ptc.com/en/support/article/CS370202
https://www.ptc.com/en/support/article/CS363846
Hope that helps.
Best,
Hi @OP_11714882 look at the reference document below and let us know your feedback.
I want to create a Windchill document from thingworx, maybe by using a POST method
Hi @OP_11714882,
Refer to articles:
Hope that helps.
Best,
