Create WTDocument in Windchill (with primary content) from Thingworx
OP_11714882
7-Bedrock
I want to create a WTDocument in Windchill which may also contain primary content from ThingWorx (by creating a form in Mashup). I'm new to Thingworx and want to know the steps to do so.
Hi @OP_11714882,
In ThingWorx, there are 2 ways you can call Windchill REST API.
First is to create a Thing Service and use ContentLoaderFunctions.
Refer to articles:
https://www.ptc.com/en/support/article/cs237875
https://www.ptc.com/en/support/article/CS380751
Second is to use Integration Connector > ODataConnector
Refer to ThingWorx Help Center
As for which Windchill API to use to create WTDocument, I found below articles, but if you have any further questions, you need to ask in PLM community board or open a Windchill support case for help.
https://www.ptc.com/en/support/article/CS370202
https://www.ptc.com/en/support/article/CS363846
Hope that helps.
Best,
Tony
Hi @OP_11714882  look at the reference document below and let us know your feedback.
https://www.ptc.com/it/support/article/CS363398
https://www.ptc.com/de/support/article/CS355890
I want to create a Windchill document from thingworx, maybe by using a POST method
Hi @OP_11714882,
Refer to articles:
Hope that helps.
Best,
Tony
