We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
I need to open a page with HTML code generated by a service, I can use:
are there other options ?
// I have thingworx 8.5.9
I found that the ValueDisply widget, specifying "html" as rendering type is the best for that.
I was able to create a relatively clean table element
Anycase .. all the html code is pushed inside the whole mashup management of thingworx (div, css, javascript ...) , and so it is not possible to do a really custom mashup with events/scripts as a normal html file allows.
Hi @iguerra,
Does the custom CSS mentioned in the following article help with the display issue in the HTML TextArea widget as Read-Only ?
In ThingWorx, HTML TextArea widget cannot display table properly in READONLY mode
Otherwise the Grid widget can also render HTML code but it might not be ideal if you have only one value to display.
Hello @c_lowy
it fixes partially
without readonly it shows table with 100% width (takes all the screen)
with readonly and the CSS I can see the table, but columns/table width is fixed
Hi @iguerra,
Indeed, this is not ideal. Note that the HTML TextArea widget has been made Read-Only only starting ThingWorx 9.0.0 and my tests showed that the tables are also properly displayed in that new version of the widget (without any additional CSS).
But I have thingworx 8.5.9 and upgrade is not planned in few time
and I have the flag to set readonly the HTML text area ...
may be I should play with CSS ??
I am currently making some tests and research to see if this can be achieved using custom CSS. I will get back to you on that point.
Hi @iguerra,
I unfortunately have not been able to find a CSS syntax that would make the HTML table stretch across the container in 8.5.
I know that is it not the most convenient solution, but if you define your HTML content as a column of an infotable and display that into an Advanced Grid, you can choose to display the HTML content with formatting and the grid cell at least will be stretched across the container. However the table itself might not so depending on the display intent the HTMLTextArea might still be preferred.
Hi @iguerra.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
