I have following scenario in ThingWorx:
A thing is created with properties: Property1, Property2, Property3, Property4 and Property5 etc.
I wish to display these property values in mashup and at the same time I want to update them from mashup itself.
How can i achieve this?
Thanks!
@Kiran1 : I believe you can use grid to display the property records and use a textbox or other widget to take input in case of updating records. With a button click then can call a custom service which updates thing property along with refreshing grid data.
Is there any specific layout or UI you are looking to achieve this functionality?
-Durgesh
Thanks for responding.
I will check this.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
