Hi all,
I want to build a menu. On each item in the menu I want to use a negative icon and a normal icon. I have seen this once in one of the ThingWorx demo's. They look like this:
How did they to it? Is there an easy way? Or did they use CSS? If CSS, can someone help me how this CSS would look like?
Kind regards,
Jasper
Hi @jasperlg.
I was provided with the attached exports which should give you some idea of how to implement the design you are looking for.
If this response provides the answers you needed, please mark it as the Accepted Solution.
--Sharon
Hi @jasperlg.
Could you provide a link to the demo or some information to help us identify who created it? We can then reach out to try to identify the method used for addressing your needs.
--Sharon
Hi @slangley ,
I found this in the Smart Farm demo from PTC.
You can Log In on this demo with the following credentials:
TWDemoB
BestPlatform
Hi @jasperlg.
Thanks for the link. I'm working to track down more information to see if we can answer your question.
--Sharon
Hi @jasperlg.
The person who created this mashup has been out of the office. I'm checking to see if someone else on her team can assist with your question.
--Sharon
Hi @jasperlg.
--Sharon
