Created Model in API doesn't show up in Analytics Builder
DF_10027356
6-Contributor
Hello all,
I have created a Time Series prediction model in the API. Than I added the JobTags but the model still does not appear in the Analytics Builder.
Does anayone has an idea how I can fix this problem?
ThingWorx Version: ThingWorx 9.0.2
Thank you already in advance.
Kind regards
David
1 REPLY 1
cmorfin
(To:DF_10027356)
Hi David
Is it possible for you to share the code you use to create the job and add the tags ?
Also note that even if the model appears in Builder, because it is an API job as opposed to a Builder one, it will not have all the functionality seen in Builder. It will mainly only be a way to list in the model table, the validation details of the model will not be available.
Christophe
