Creating Multiple User Login in Thingworx
VS_9760165
Hi
I am looking create multiple user login and based on user i have to give particular mashup access and how session can be handled for each user ? can we create this using Organization?
Vaibhav
odukiya
(To:VS_9760165)
Hello @VS_9760165
Yes. So the TWX server manage the User Sessions by the User name, if you login with different User name, the session will be logged separately, if you login with same User in different machine/ browser, the login will be updated, and probably you'll sign in the latest page.
If it has answered your query please mark the appropriate reply as solution. In case you have further query , please revert.
Om Dukiya
odukiya
(To:VS_9760165)
Hi @VS_9760165 ,
the multi-user login creates different sessions, the permission for each login only depends on the User you used. So configure the User permissions carefully would grant them different access.
The Organization gives Users 2 rights:
1. Visibility permission to entities
2. FormLogin access to Home Mashup of the Organization.
Om Dukiya
VS_9760165
(To:odukiya)
Hi @odukiya ,
Please Correct me if i am wrong.  When we assign multiple user while creating organization then only it creates session for each user right?
odukiya
(To:VS_9760165)
Hello @VS_9760165
Om Dukiya
VS_9760165
(To:odukiya)
@odukiya ,
Thank you for reply, i have one issue that i have created one organization for administrator login,
But when i logout and go back on browser its not asking for login again. I need to terminate the session on logout . How we can do it?
Thank you
odukiya
(To:VS_9760165)
Hello @VS_9760165
I hope this article can help
https://www.ptc.com/en/support/article/CS321910
Om Dukiya
