Creating a new widget
giladl
Hello guys,
I would like to divide my mash-up to 2 parts.
On the left side, dashboard with 16 gauges.
On the right side a web-frame that displays an html page for each gauge that you click on from the left side.
how should i do that?
thank you,
Gil.
3 REPLIES 3
paic
(To:giladl)
I would look into the use of a Repeater with Selection enabled to do this in an efficient way.
Else you can overlay a hidden button on top of the Gauge which feeds the link to the web-frame
The  biggest challenge you have going this route, is the fact that you have to somehow come up with some client side logic using the expression widget/validation widget and some parameters to get only 1 final result to feed into the web frame.
So the repeater is a much better way to go.
There may be some other solutions possible
giladl
(To:paic)
Hello PaiC,
Thank you for your help.
Unfortunately the repeater isn't the way I'm looking for. As for the hidden button, it is a good way, but it canceling the responsiveness of the mash (by default, I may have to use this way).
Is there a possibility to create a new gauge widget with an extension of clicking by a SDK?
Gil
paic
(To:giladl)
Hi Gil,
you can always create your own widgets if you have that need. You can take a look at the Gauge and Button code to use that as a basis to create your own.
Please be sure to create it as a new extension vs. a modification of the existing widget. You can more information on this in the Wiki.
