Creo Insight Extension:Problem to define the Force_Sensor_A.prt
titurbina
 Creo Insight Extension:Problem failure to define the Force_Sensor_A.prt parameter
 Tank you
3 REPLIES 3
slangley
23-Emerald II
(To:titurbina)
Hi @titurbina.
Which version of ThingWorx are you running?  What version of the extension are you using?  Which version of Analytics are you running? Which version of Creo are you running?
--Sharon
titurbina
(To:slangley)
What version of ThingWorx are you using? ThingWorx_Analytics_Console_Extension 8.4.0
What version of the extension are you using? Produc Insight by PTC Creo 7.0.0.0
Which version of Analytics are you using? PTC Creo Simulation Multibody and Creo Simulation Live, Option Modeler
  What version of Creo are you using? PTC Creo 7.0.0.0
slangley
23-Emerald II
(To:titurbina)
Hi @titurbina.
Please provide the version of ThingWorx platform you're running. This is needed for confirming compatibility between product versions.  From Composer, you can find it by selecting Help > About.
--Sharon
