Css changes not visible in modal popup for date picker and button widgets.
shraddha_21
Hi Community team,
I have two widgets one date picker and another one button to come up in modal popup but the css i have applied is not visible there which is showing up when I'm normally opening the popup mashup as in not from navigation.
 version is 8.5.7
Shraddha
hi @shraddha_21 ,
I face this problem daily, so for the CSS you have applied, you need to put the #root before it. The #root you will get it when you open the popup from runtime and do an inspection on it.. for example:
So you need write code like:
#cell_Section_Aggregation_Flow-73_navigation-60-popup_panel-351 {
    background: transparent;
    -ms-filter: progid:DXImageTransform.Microsoft.gradient(enabled=false);
    filter: none;
    border: none;
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
hi @shraddha_21 ,
    filter: none;
    border: none;
Shashi Preetham,
