Hi Community team,
I have two widgets one date picker and another one button to come up in modal popup but the css i have applied is not visible there which is showing up when I'm normally opening the popup mashup as in not from navigation.
version is 8.5.7
Shraddha
hi @shraddha_21 ,
I face this problem daily, so for the CSS you have applied, you need to put the #root before it. The #root you will get it when you open the popup from runtime and do an inspection on it.. for example:
So you need write code like:
#cell_Section_Aggregation_Flow-73_navigation-60-popup_panel-351 {
background: transparent;
-ms-filter: progid:DXImageTransform.Microsoft.gradient(enabled=false);
filter: none;
border: none;
hi @shraddha_21 ,
filter: none;
border: none;
