Hi All,
When I follow the document
https://developer.thingworx.com/en/resources/guides/create-authentication-extension
And then try to login using the TestSite.html, I get the following error in the security log.
Debug | Filter set to SAMEORIGIN - sending same origin |
I suspect there is some web.xml setting that I am missing.
After the authentication request, I am redirected to /Thingworx/ActionLogin/CustomLogin
with 404 error.
Manas
I was performing authentication from localhost to a thingworx foundation server on localhost.
However, I contacted the support and the solution which they recommended is to change the URI
from "/Thingworx/ActionLogin/CustomLogin" to "/Thingworx/action-login" in two places,
1. The authenticator extension
2. The HTML client file
It seems to work, but I have to test it in detail.
Are you performing this authentication from a localhost to a ThingWorx Foundation server on localhost, OR are these on two different servers/hosts?
Hi @manasvi.
Please let us know how your testing is going. Once you have validated, it would be greatly appreciated if you would mark your reply as the Accepted Solution for the benefit of others with the same question.
--Sharon
