I couldn't find any documentation regarding how to use custom dialog when developing custom widgets from any of these documentations. Are there any documentation for custom dialogs?
taken from thingworx_extension_development_user_guide.pdf
Hello @DK_10003244 ,
Hope you are doing well!
I have checked the links mentioned in the query and seems like you are referring to an old guide: https://support.ptc.com/WCMS/files/170215/en/thingworx_extension_development_user_guide.pdf?
You can explore some latest documents custom Widgets/ Extensions:
Article: https://www.ptc.com/en/support/article/CS201191
Help center guide link: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Best_Practices_for_Developing_Applications/EclipsePluginInstallingThePlugin.html
Community Tutorial: https://community.ptc.com/t5/IoT-Tips/Create-An-Extension-Part-1/ta-p/827938
Kindly check the above attached links. Let me know if it helps.
Bhawna
Hi @bchaudhary
Thank you for the response,
The link you provided writes the exact same thing as the documentation in 2015 and 2018.
I also found other community posts regarding this topic that also refer to the documentation I provided above.
It doesn't mention anything about customEditor like grid or mashup
Hi @DK_10003244.
What version or ThingWorx are you running? The 9.x documentation for extension development can be found here.
Regards.
--Sharon
Hi @slangley,
Thank you for your response,
I couldn't find any information regarding custom dialog on the link you provided, along with the Lit Component version for 9.4.x and above.
So it can be concluded that the devs can't use any custom dialog when developing a custom widget?
I believe Sharon has shared the right link with you. If you are developing a lint widget, you can also look for any lint custom dialog. Also, You can use SimpleJavaScript Dialog.
Bhawna
Hello @bchaudhary,
Sorry, but I couldn't find the SimpleJavaScript Dialog that you are mentioning on any link that Sharon shared.
I think this topic is leading the wrong way. Maybe I'll rephrase my question. What I meant was how to create this dialog when developing or creating a Custom Widget. This is the example dialog from Mashup. Another widget that has this dialog is the Grid Widget. By using this dialog, we can make the widget configuration to the next level.
Thanks!
