Hi ,
Creating/Working on the Custom Widgets, is there any already made widgets available for PTC side or through any Github, where team can explore and experiment the custom widgets for Thingworx 9.3 version.
@slangley @c_lowy @CarlesColl @paic
Shashi.
So,
PTC provides a few Thingworx Custom Charts Extension codes on the PTC Software Download Page. This solved the trouble of Creating a new Custom widget. Instead of a slight modification in the Code provided by the PTC solved the issue.
Also Github has lot of open source Thingworx Widgets, but try on own risk.
Shashi.
Hello @Shashi_Preetham ,
Pls check the following article hub:
https://www.ptc.com/en/support/article/cs332429
Also, this one explain how to create a custom Widget:
https://www.ptc.com/en/support/article/cs201191
Regards
Bhawna
So,
Shashi.
