Hi All,
I have created a custom widget, I can add it to my mashup. But when I view mashup that widget disappears and error shows <widgetName> doesn't exist.
I am attaching screenshots and extension zip file for reference.
Worked for me when I imported it (see attached). Note that after I imported it into 9.0.1 I did do a hard reload and cache clear (open up your browser console, hold down your mouse on the page refresh, and select Empty Cache and Hard Reload) on the Composer. You'd probably want to do this on your mashup page as well
No errors there, few warnings though.
Hi @SK_9454947.
I have changed the Accepted Solution for this post. If you disagree that it is the solution, please let me know.
--Sharon
