CustomAuthenticator doesn't work for URL /Thingworx/FormLogin
seanccc
I created a CustomAuthenticator and want to catch the login request to redirect to another page.  however, I found the request /Thingworx/FormLogin won't be intercepted by matchesAuthRequest
matchesAuthRequest(HttpServletRequest httpRequest)
that's strange,  the other GET request , for example both of /Thingworx/Home and /Thingworx/Composer can be intercepted by this method .
Is the URL /Thingworx/FormLogin ignored by the servlet filter intently ?
Sean
seanccc
(To:seanccc)
It's solved by adding AuthenticationFilter mapping url pattern "/FormLogin/*"  in tomcat's web.xml
2 REPLIES 2
seanccc
(To:seanccc)
slangley
(To:seanccc)
Hi @seanccc.
Since you found the solution to your problem, please mark your response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
