Customize Reset Password Screen
pshashipreetham
18-Opal
When you try to log in through the below URL
http://localhost:8081/Thingworx/FormLogin/confirm/TestLogin
You get a Login form with a Reset button, and another form appears when you press the Reset Password.
Business wants to customize the dashboard. Is there a way to do it?
As per the link here, I can see we need to customize the JSP files, isn't there other way?
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
Hi @pshashipreetham
Kindly look at the following file at line number 19, and change it according to your requirements.
webapps\Thingworx\Common\locales\en\translation-login.json
The available customization options are present in the Help Center, here.
What exactly is it needed that can not be done with those options?
Hi @VladimirRosu,
I would like to Customise the Reset Password page also, for example, the customer wants to remove the below text:
Shashi Preetham,
Hi @pshashipreetham
Hi @pshashipreetham
Let us know if your issue persists otherwise, mark it as a solution.
Surya
