Data Change Event permission
AliBenBelgacem
I have a problem with datachange event when i authantificate with w new created user.
Explanation:
I developed a thing worx application. Now , i am creating a user for the application.
1- I created Organisation
2- Creted two groups (Admins groups and simple users groups), each group contain a user .
3- I add right access to the two groups (Visibility, design Time , Run time) to all entities (mashup, Things, Thing template, Thing shape ...).
4- Authantificate with the admin user created for the appli.
5- When i try to open the thing template subscription function, i get this error (see attached file: Event Error), it's related to 'DataChange' Events
6- in the logs :
Timestamp  Level Content User Origin Thread Session Instance
2019-09-30 15:35:13.788  Error [message: Entity Not Found : [Event]] MrttAdmin c.t.w.DataShapes http-nio-8443-exec-18
2019-09-30 15:35:12.740  Error [message: Entity Not Found : [Event]] MrttAdmin c.t.w.DataShapes http-nio-8443-exec-9
See file attached.
I thing that the error come form event datashape permission ( i already add event permission to users but always get the same problem)
Thank you for your help.
I would agree with your way of thinking. You probably need to add visibility to this data shape.
/ Constantine
Hi Canstantine,
This is already done but it didn't rosolve my problem !
I add the permission to event datashape and datachange event datashape. same error !
