Data Filter and Column Sort with Advanced Grid
jsimms
7-Bedrock
I'm having trouble getting Data Filter Widget to work with Advanced grid when Column Sorting is enabled. I tried passing the query from the Data Filter Widget to the Advanced Grid and then from there to the QueryDataTableEntries Service. The Data Filter works but when I uncheck filters the displayed data does not change. Included video for clarity.
jsimms
7-Bedrock
(To:jsimms)
I just a talked to support. This issue is supposed to be fixed in version 8.5.
https://www.ptc.com/en/support/article?n=CS306055
10 REPLIES 10
posipova
20-Turquoise
(To:jsimms)
Have you compared your bindings to  the sample Mashup provided, WeatherExample? It's packaged with the grid advanced extension. I just tested sorting + data filter and it works fine in my 8.4.2
jsimms
7-Bedrock
(To:posipova)
Yes they seem to match.
Data Filter Bindings:
AdvancedGrid Bindings:
posipova
20-Turquoise
(To:jsimms)
Do you experience the same issue when loading/viewing the WeatherExample?
jsimms
7-Bedrock
(To:posipova)
I can not see the data when loading the weather example is the data table supposed to be empty?
posipova
20-Turquoise
(To:jsimms)
You are supposed to run a service to populte the table first (please see the pdf instructions packaged with the extension)
jsimms
7-Bedrock
(To:posipova)
Ok. I did that and I am still experiencing this error.
posipova
20-Turquoise
(To:jsimms)
Do you mean the same error as in your non-example grid or just a blank in the advanced grid example? At this rate may need to open a support ticket to dedicate a resource for investigation.
jsimms
7-Bedrock
(To:posipova)
The same error that happened in my non example grid. I'll go ahead and do that. Thank you for the help.
jsimms
7-Bedrock
(To:jsimms)
posipova
20-Turquoise
(To:jsimms)
Thank you for letting me know!
