Data Filter and Column Sort with Advanced Grid
SOLVED
Regular Member
I'm having trouble getting Data Filter Widget to work with Advanced grid when Column Sorting is enabled. I tried passing the query from the Data Filter Widget to the Advanced Grid and then from there to the QueryDataTableEntries Service. The Data Filter works but when I uncheck filters the displayed data does not change. Included video for clarity.
1 ACCEPTED SOLUTION
Re: Data Filter and Column Sort with Advanced Grid
I just a talked to support. This issue is supposed to be fixed in version 8.5.
https://www.ptc.com/en/support/article?n=CS306055
10 REPLIES 10
Have you compared your bindings to  the sample Mashup provided, WeatherExample? It's packaged with the grid advanced extension. I just tested sorting + data filter and it works fine in my 8.4.2
Yes they seem to match.
Data Filter Bindings:
AdvancedGrid Bindings:
Do you experience the same issue when loading/viewing the WeatherExample?
Highlighted
I can not see the data when loading the weather example is the data table supposed to be empty?
You are supposed to run a service to populte the table first (please see the pdf instructions packaged with the extension)
Ok. I did that and I am still experiencing this error.
Do you mean the same error as in your non-example grid or just a blank in the advanced grid example? At this rate may need to open a support ticket to dedicate a resource for investigation.
The same error that happened in my non example grid. I'll go ahead and do that. Thank you for the help.
