I'm having trouble getting Data Filter Widget to work with Advanced grid when Column Sorting is enabled. I tried passing the query from the Data Filter Widget to the Advanced Grid and then from there to the QueryDataTableEntries Service. The Data Filter works but when I uncheck filters the displayed data does not change. Included video for clarity.
I just a talked to support. This issue is supposed to be fixed in version 8.5.
Have you compared your bindings to the sample Mashup provided, WeatherExample? It's packaged with the grid advanced extension. I just tested sorting + data filter and it works fine in my 8.4.2
Yes they seem to match.
Data Filter Bindings:
AdvancedGrid Bindings:
Do you experience the same issue when loading/viewing the WeatherExample?
I can not see the data when loading the weather example is the data table supposed to be empty?
You are supposed to run a service to populte the table first (please see the pdf instructions packaged with the extension)
Ok. I did that and I am still experiencing this error.
The same error that happened in my non example grid. I'll go ahead and do that. Thank you for the help.
Thank you for letting me know!
