Data Logger
pshashipreetham
Data Logger
When Ever Kepware is getting the data from the DB/SQL Server, the tags are getting created by the name "table7_channel1_device1_property_name", I don't want table7 in the tag names. I can't rename the 470 tags by manually modifying each and every tag.
What is the best solution?
Shashi Preetham.
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
Hi @PaiChung ,
I have renamed all tags, manually.
Shashi
Shashi Preetham,
5 REPLIES 5
For what reason do you need to have that removed from the tags?
Since these usually are bound to something else, the tag names are abstracted away for the end user.
Hi @PaiChung,
for Business logic I need to remove this table6 in the tag names, can it be done?
if it can be done, then how?
Shashi
Shashi Preetham,
I'm not too familiar with how your tags are coming in and how you want to use them.
If you are just pulling a table with tags in it, you can use a regex or something similar perhaps to remove them.
Hi @PaiChung ,
Shashi
Shashi Preetham,
Hi @pshashipreetham
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
