I have connected an SQL Server to the Kepware Data Logger, Whatever the data is coming from the tags should go to the DB instead of the Thingworx.
I wanna Remove the Thingworx IP from the Project --> Properties --> Thingworx ---> Remove Thingworx Interface and want to send the data to a SQL SERVER using Data Logger.
How can I do it?
@c_lowy
By Disabling the Thingworx interface from the Project---> Properties ---> Thingworx---> Server Interface, change it to No.
The above setting worked for me.
@pshashipreetham : Have you checked the below links which describe setting up dataloggers?
Video guide: https://www.youtube.com/watch?
Documentation: https://www.kepware.com/getatt
@pshashipreetham : Can you please try setting dataloggers as per below links?
Video guide: https://ind01.safelinks.protec
Documentation: https://ind01.safelinks.protec
