DataTable not running
Tomellache2B
Hi Community,
Please can someone assist me with this?
I have created a data table and given it a datashape.  When I go and see the mashup, I'd expect to at least see the columns appear without any data.
However there are no columns. When I run getDataTableEntries, I get a script this error: 'dataTable is not running'.
What does this mean? how does can I remedy this?
Tomellache2B
(To:jensc)
I the error log was complaining about the persistent provider on the datatable. Previously it was set to influx DB so I changed it to Thingworx persistent provider, then the columns appeared on the datatable mashup.
Thank you.
Did you try running the "RestartThing" service?
I don't see that you should have to, but you never know.
Also, is there any error messages in the logs that might help us?
Jens
Tomellache2B
(To:jensc)
Thank you.
