we have created a DB Thing Template and created a 50 thing inheriting the DB Thing Template.
then we have exported the both Thing and thing template from server and imported to another new thingworx server. we have changed the JDBC connection in DB Thing Template but it is not reflecting in the inherited thing.
we have to manually configure the 50 things separately..
is there any workaround for this.
Thanks in Ad
Once the Thing is instantiated from the template, the configuration values will no longer update.
If you need that to happen, I would recommend you script a service that pushes configuration table updates to your Things
That is probably better than deleting and recreating the things? (can also be scripted)
