Database log in the Monitoring menu.
SKannapiran
Could you please guide me on how to include the "Database log" under the Logs in Monitoring menu of ThingWorx composer. By default, other logs such as Application Log, Communication Log, Configuration Log, Script Log, etc., are available. To see the Database log, I need to connect to the ThingWorx server.
It would be more helpful if this log could be made available in the Monitoring menu. Kindly guide me with the steps. Thanks
slangley
23-Emerald II
(To:SKannapiran)
Hi @SKannapiran.
The logs you see in ThingWorx are generated by the ThingWorx app, whereas the database logs are generated by the RDBMS used in your implementation.
I recommend submitting a request for this on the ThingWorx Ideas forum.  That will allow others to vote for it which will increase it's changes of consideration in a future release.
--Sharon
1 REPLY 1
slangley
23-Emerald II
(To:SKannapiran)
Hi @SKannapiran.
--Sharon
