Cannot find DatabaseLog in Thingworx 9.1.0 Monitoring logs but able to see the same in thingworx 9.0.0
Could you please help me If I have to make any changes
GetLogEntries will only work for below logs.
One of the possible solutions to load the Database log in a mashup is via a custom extension. You can refer this article, it explains how to get contents of a file on a drive from ThingWorx service.
Sachin Sharma
var logTable = Logs["DatabaseLog"].GetLogEntries({
oldestFirst: true /* BOOLEAN */,
maxItems: 67 /* NUMBER */
result = logTable;
The above code works only for the logs displayed in Monitoring logs where as it doesnt work for DatabaseLog
Any workaround for this?
I did not get any update on the above query.Can you respond on it
Sachin Sharma
