Hello Everyone,
I have Question If Possible have date pickup inside Grid table
in the below table for daily action i want when the Clint click on Due date open date widget to select instate of write by hand
Islam
Assuming your actions (rows) already exist, then
1.Double click a row
2. use navigation widget to open a new popup mashup
3. pass parameter of the ROW_ID to the new popup
4. use a date widget so Client can enter or select a date
5. use button to trigger a SQL UPDATE service for the ROW_ID
6. on close of the popup, refresh the grid, so client can see the updated row with date
this way you add a date to existing action
Hello @MichalC
Thanks for Support
i I believe that right way to do it , Could you Please explain with Pic
Islam Amer
What part you don't understand?
How to pass parameter of the ROW_ID to the new popup ?
Hello @MichalC
Thanks for Support
Islam Amer
