Hi all,
I'm facing an issue with Date Time Picker widget that auto converts the picked time (e.g. 03-08-2023 00:00:00 GMT+2) to the GMT 00 Time (e.g. 02-08-2023 22:00:00 GMT 00). And because I'm in Germany this is can be solved by statically adding +2 to the selected datetime, but it has to also check the so called Daylight Save Time that sometimes can affect the time shifting between GMT+2 and GMT+1.
Applying getTimezoneOffset() won't work because it's already converted directly to GMT 00 (UTC) which means applying getTimezoneOffset() will always return 0.
Is there a way to avoid the timezone conversion between the Date Time Picker widget so that if my customers from all over the world select 03.08.2023 00:00:00 on the Date Time Picker widget it will be also understood and processed further as 03.08.2023 00:00:00 GMT 00 no matter where they are, and regardless the Daylight Saving Time that may vary.
Hello @nikkolasep
I'll post this here for you do go over if you haven't already.
It is an support article giving some examples on how to "not" convert dates.
But not sure if it covers your exact use case
Jens
Hello @nikkolasep
Jens
