Delete Infotable row based on selected row values
Aleksandar
7-Bedrock
var size = me.Intruders.getRowCount();
var i=0;
for (i=0;i<size;i++)
if (me.Intruders.rows.Age == Intruders.Age){
DeleteItem(i);
break;
function DeleteItem(i)
{ if(i!=0){
me.Intruders.RemoveRow(i);
This is not working , can someone help?
Intruders.Age is a selected row infotable (input parameter) and I am looking to delete a row from Intruders infotable with the Age from selected row.
var i;
if (me.Intruders.rows[i].Age == Intruders.Age){
result = "nice";
var myTempTable = me.Intruders;
myTempTable.RemoveRow(i);
me.Intruders = myTempTable;
break;
Thank you for the help, here is the working code if someone needs it.
It deletes the date based on row parameter.
PaiChung
22-Sapphire I
(To:Aleksandar)
When you say this is not working, are you getting errors?
Is the infotable persisted or not?
you are doing a direct in memory operation which would mean that is the infotable is persisted, it will retain the original content after a thing restart or system restart.
There are no errors, Yes the infotable is presisted.
The Service does not delete a row because the infotable is persisted ?
After the executions, the specific row is still there. It doesn't delete it.
PaiChung
22-Sapphire I
(To:Aleksandar)
To make a persistent delete in an InfoTable property you have to completely re-write the property
so
Try accessing the value of the property directly. Use +me.Intruders.rows.Age in your if condition statement.
Like : if (+me.Intruders.rows.Age == Intruders.Age).
var i;
result = "nice";
break;
