I have working Machine learning Model developed in R studio. I need to deploy that code in ThingWorx platform.
Could you please help me in finding options for this?
Vamsi
To close this community thread:
@Vamsiakula: would you mind marking this response as a solution in order to close the community thread. Thanks!
Regarding the Docker Container in ThingWorx Analytics
It is not supported as of now. You can also refer to this article.
Regarding the pmml query
Kindly refer to this article provided by Mohit in the above reply.
Best Regards,
Prakhar Shubham
Hi Vamsi,
I request you to go through this article and confirm if this is what you are seeking.
Thank you
Best Regards,
Prakhar Shubham
Thanks for your response Prakhar Shubham. I will check this PMML option.
Another point I have is, I have created a docker container Image of the R model.
can ThingWorx analytics support docker container image? if yes, how to use Containers in ThingWorx.
Vamsi
Hi Vamsi,
Can you please clarify the part where you said that 'I have created a docker image container of the R model'. It would be great if you can just elaborate a bit around this.
Best regards,
Prakhar Shubham
Hi Vamsi,
I would really appreciate if you could respond to the above question.
Thanks!
Best regards,
Prakhar Shubham
Hi @pshubham
We had Support cases for above queries. Cases have already been closed. Below articles will help on this.
How to use Docker container in ThingWorx Analytics: https://www.ptc.com/en/support/article?n=CS290730
How to import PMML model and use in Analytics manager: https://www.ptc.com/en/support/article?n=CS267119
Mohit
I have generated a Docker container Image of my R machine learning Model script and am trying to check whether this image can be used in ThingWorx for real time scoring?
We tried similar thing in other IOT platform like MS AZURE.
Vamsi
Hi @Vamsiakula
ThingWorx Analytics accepts PMML file to real time scoring on Predictive model. You need to convert R script in to PMML form to do it.
Follow the below article, hope this will work:
Mohit
Best Regards,
Prakhar Shubham
Hi @Vamsiakula
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
