How to disable the tool tip for the line chart in thingworx 9.3
@paic @CarlesColl @c_lowy @slangley @VladimirN
Shashi
Hi @pshashipreetham.
I'm not seeing a way to remove the tooltip. The ability to hide tooltips is a request we have received in the past but it was not approved due to limited support of the idea.
If you are interested in pursuing this, you can post a new request in the ThingWorx Ideas Board. With enough votes, it will be considered for a future release.
--Sharon
--Sharon
Hi @slangley ,
Thanks for the quick response, is there any work around as of now, to hide this through CSS or something on the Charts(line) ?
Shashi.
I haven't done too much with CSS but I don't think that would work. The only other option I can think of is to create your own widget.
--Sharon
