Displaying value in rectangle with State formatting
VaibhavShinde
Hi ,
I am looking for a widget which shows value and State formatting also . Please help me to get this type of widget.
i have shown below screenshot which is my requirement. one rectangle which holds a value/data and depends on value it should change the border color. but i m not getting Widget name?
You can overlay two widgets on top of each other to get this effect.
A Shape and Value display
4 REPLIES 4
Hi PaiChung,
I have tried with Shape widget with value display in twx 8.5.2 , if i overlay display widget on top of Shape it is disappearing at runtime , and also i am unable to change the size of Display widget , checked after binding data as well.
Thank you
Hello @VaibhavShinde,
Try to add two value display widgets with different style, and control their visibility via a validator.
/ Constantine
If you cannot solve the overlay problem, you can just resize the Shape widget (close to a narrow line) and put 4 of them around the Valuedisplay widget, and form the frame you needed.
