Do we Have PDF export option(Extension) from Mashup? Or How to?
Janakiraman-P
Hi all,
I want to document input fields and grid data in to PDF format, Do we have any option for that?
Janakiraman P
For the pdf extension we recommend creating a purpose built mashup.
So you would create an additional mashup that has the look of what you want to produce in your pdf
6 REPLIES 6
There are some extensions in the Marketplace that can publish content to PDF.
You could also use the regular Print function and print to PDF
could also create some download file based on the parameters which then can be printed to pdf.
Thanks for your response.
The requirement is to convert to PDF and store it in the repository. The print option printing the entire Mashup which has irrelevant content as well.
And,
Can you suggest any extension which has proper documentation. I gone thru some extensions which don`t even have the ReadMe file.
ex. solr
Thank you,
Janakiraman P
Hi @Janakiraman-P ,
Try PDF Extension.
PDF Extension, which is available in marketplace, can convert mashups into pdf format and you could download the same from repository.
With regards
Yedukrishnan
Hi @Janakiraman-P
Try the attached extension
With regards
Yedukrishnan
I have tried above attached PDFExtension, it is capturing the entire mashup to generate pdf.
As I mentioned above, I need to avoid some unwanted content from the mashup. And considering grid in this, if grid has scroll bar then it is not helpful.
I think, I have to create custom extension in this case.
Thank you,
Janakiraman P
