If I understand well what you want to do, you should do something like:
var dynamicNameHere = "myCustomFieldName"; var newRow = {}; newRow[dynamicNameHere] = table.rows[0][dynamicNameHere]; AttTable.AddRow(newRow);
Thank you for the response! How would it look if I was also adding values for known table headers in that same add row function? Would I just tack on to that string "newRow"?
New row it's a Javascript object not a String, and yes you can add as many fields as you want :
var newRow = { myField1: "myFieldValue1", myField2: 12.0 }; newRow[dynamicField1] = "dynamicFieldValue1"; newRow[dynamicField2] = "dynamicFieldValue2"; newRow["thirdDynamicField"] = 10.3;
This worked perfectly! Thank you!
Hello -
If this solution met your needs, could you please mark the question as solved?
-Chris Kaminski
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
