Dynamic Field for AddRow function
ptc-6292144
3-Visitor
Hey everyone. I need help to figure out how to code a dynamic field name in a params clause. Below is the example of code.
AttTable.AddRow({
DYNAMICNAMEHERE: table.rows[0].DYNAMICNAMEHERE})
For the DYNAMICNAMEHERE I am declaring the variable value farther up in the code and referencing it as the variable name in those two sections but it isn’t working.
If I understand well what you want to do, you should do something like:
var dynamicNameHere = "myCustomFieldName";
var newRow = {};
newRow[dynamicNameHere] = table.rows[0][dynamicNameHere];
AttTable.AddRow(newRow);
var newRow = {};
Thank you for the response! How would it look if I was also adding values for known table headers in that same add row function? Would I just tack on to that string "newRow"?
New row it's a Javascript object not a String, and yes you can add as many fields as you want :
var newRow = { myField1: "myFieldValue1", myField2: 12.0 };
newRow[dynamicField1] = "dynamicFieldValue1";
newRow[dynamicField2] = "dynamicFieldValue2";
newRow["thirdDynamicField"] = 10.3;
This worked perfectly! Thank you!
ckaminski
(To:ptc-6292144)
Hello -
  If this solution met your needs, could you please mark the question as solved?
-Chris Kaminski
