Dynamically Scale a Picture Based on Widget Dragging (Left = Zoom In / Right = Zoom out)
MA8731174
Hi everyone,
I’m working on a UI feature in ThingWorx Mashup and was wondering if something like the following is possible:
I have a layout where a picture (or model view) is shown on one side, and I want to dynamically change its size based on how I drag a divider or a panel.
  • When I drag the divider to the left (making the picture area larger), the image or 3D model should grow (scale up).
  • When I drag it to the right (making the area smaller), it should shrink accordingly.
The idea is to simulate a sort of "zoom effect" by using the container resizing rather than zooming through buttons or manual controls.
Here's a screenshot for visual context:
(Attached image showing the mashup and panel layout with the drag area)
Has anyone tried implementing something like this before?
  • Is it possible to bind the widget size or scaling dynamically to container resizing in ThingWorx?
  • Or is there a workaround with CSS or JS injection?
Any ideas or tips would be greatly appreciated!
Thanks in advance!
I tried a little but did not find the "perfect" solution. Attached one kinda works with collection mode "table" - to some extend. Max size is limited by "cell height", which also needs to fit the screen.
Maybe it helps.
I also found https://community.ptc.com/t5/ThingWorx-Developers/Making-a-collection-responsive/td-p/732023 which has similar question but also not the perfect solution.
With a Image you can achieve what you want
At least this is what I think you want? Not sure if your right widget for 3d viewer supports such options (position + scaling)?
Thank you for your reply! As you can see that this is a dynamic panel and in which i have collection and these collection have images. It can be more then one images there also.
Okay. Not so sure. I did not find a bindable width property of the dynamic panel, which one could use as width for the collection tiles.
Also not sure how the tiles would resize when using the collection-widget setting 'UseMashupDimensions' and letting the mashup be responsive.
Other than that I would not have another idea currently.. Would need to try how the behavior is - but maybe you already tried that...
Maybe it helps.
Hi @MA8731174 ,
It appears that there is a possible workaround to your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
