I am new in thingworx. I am trying to connect a Raspberry Pi to ThingWorx using the Edge Micro Server. After following all the steps in the "Raspberry Pi Quickstart" guide during Run LSR step I got following error
[DEBUG] 12/Jul/2017:09:59:14 [+0000] HTTP Server: 0.0.0.0 - SeqId 76 - "POST /Thingworx/Things/*PiThing/Services/GetPropertySubscriptions HTTP/1.1" 500 0 "-".
For your reference, I had attached my config.lua, config.json, PiTemplate.lua and the logs.
Please help me if anyone solves this issue before. Thank you in advance.
Hi Sankaralingam, just to confirm do you not see any Unbound thing on the platform i.e. in the ThingWorx Composer > Monitoring > Status > Remote Things > Unbound
Since you seem to be creating PiThing as a Gateway with Autobound so i think it should be visible in the unbound if you haven't created corresponding thing in ThingWorx. Your connection seems to be happening correctly i can't see any connectivity errors in the log.
