I am using EMS version 5.3 for tunneling but even though the gateway is turned on TW 8.3 composer it telling its disconnected. I see it connected on the TW 8.3 composer when I restart the gateway.
Does the EMS version 5.4 work better with TW 8.3?
Hi Jain,
There has been some Linux connectivity issues in 5.3.
Please Try 5.4 as it has some fixes to earlier version.
Thank you.
Hi Jain,
Thank you.
Hi @JAIN11203.
If the response from @gnandyala provided a solution to your problem, please mark it as the Accepted Solution for others who may have the same question.
--Sharon
