ERROR - series cleanup error: TypeError: Cannot read property 'hide' of null
iguerra
At every mashup change from menu I get the log above on the browser logs
I read old topics and seems was related to a google map extension, but seems not be the case (I removed also google map extension)
The pages are opened correctly, I have no errors on thingworx script or application logs
Sometimes the property name is not 'hide' but a property used on the pages, got from a data entity
It this something known ?
I have thingworx 8.5.3 cloud hosted
slangley
23-Emerald II
(To:slangley)
Hi @iguerra.
ThingWorx 9.0, which contains a fix for this issue, has been released and is available for download here.
If you feel your question has now been answered, please mark the appropriate reply as the Accepted Solution for the benefit of others in the community.
--Sharon
6 REPLIES 6
slangley
23-Emerald II
(To:iguerra)
Hi @iguerra.
Since this is a hosted implementation, we will need to open a case for further investigation.  With your approval, I'll be happy to do so on your behalf.
--Sharon
iguerra
(To:slangley)
Yes Thanks
Kind Regards
slangley
23-Emerald II
(To:slangley)
Hi @iguerra.
A case has been opened and a Support Services engineer should be reaching out shortly.  I will provide the case number under private email.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @iguerra.
The case number is 15328931.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @iguerra.
--Sharon
slangley
23-Emerald II
(To:iguerra)
For others on the community, this issue has been reported to R&D and accepted as a bug.  It is targeted for fix in the 9.0 release.
--Sharon
